Rhysaj
Newbie
Message 1 of 2
Bt sport streams
Question I have is it says you can have two streams at the same time running for by sport
but does watching bt sport through the tv count as one of the streams so streaming through tv and can stream on 1 more device or would it be watching bt sport through the tv and be able to stream on 2 more devices as well another question I have also is there a way to see what devices  being used to stream bt sport and control them/remove them?
1 REPLY 1
Distinguished Guru
Distinguished Guru
Message 2 of 2
Re: Bt sport streams
If you are using the BT Sport app or the BT Sport online player to watch then they would count as a stream.
If you have BT Sport channels as part of your BT TV (Youview box) subscribed channels then watching   the TV channel via  your Youview box would not count.
