mikef
Message 1 of 4
Can I check...access question...?
If you have the YouView box rather than the BT Vision box...but no access to Infinity...there is no way to view the sports channels on a TV?
I think I can have access via a PC or Tablet device though?
I seriously wish I hadnt bothered with the YouView box TBH.
cheers
3 REPLIES 3
carlj64
Message 2 of 4
Re: Can I check...access question...?
Youview box lacks the card slot for decryption.
I've just bought an Android device that plugs into hdmi and means I can watch app on big screen upstairs - set me back about £20 from amazon.
mikef
Message 3 of 4
Thanks, so I'm correct...
What I need then is some device/mechanism to connect either my tablet or my laptop to the TV, but I will not be able to watch directly through my YouView box.
Distinguished Guru
Message 4 of 4
Assuming AirPlay is not disabled in the yet to be seen App then it shoud playable on the TV through an Apple TV box
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
