McG
Message 1 of 9
Can I get 4k?
I have struggled with online live chat and general browsing to figure this out, can I get the 4K BT sport option? I am already on the MAX HD package at £49.99 and my download speed sync figure shows "54.488Mbps" in my router homepage.
thanks
8 REPLIES 8
ozsat
Recognised Expert
Message 2 of 9
Re: Can I get 4k?
In you BT account page you can select TV add-ons.  If 4K is available it appears as on option to add.
I assumed by speeds were good but it was never listed and customer service could not add it.
Then one day - without a speed increase - it appeared on the website list.
I called customer services to double check and they added it.
Fibre 2 Unlimited using BT Hub 6A with BT TV Box Pro (UHD/HDR) via 5GHz WiFi.
McG
Message 3 of 9
Re: Can I get 4k?
It does not appear as an option to order for me, however I stream netflix 4k without problem. Strange I am not eligable for BT sport 4k....
-Richie-
Guru
Message 4 of 9
Re: Can I get 4k?
If your minimum estimated speed is above 44 mbps then yes, you can upgrade, if the estimate is lower you can't.
McG
Message 5 of 9
Re: Can I get 4k?
Who can tell me my minimum average then?
-Richie-
Guru
Message 6 of 9
Re: Can I get 4k?
Ring 0800 800 150 and speak with the Loyalty or Value team, they're open from 8am until 9pm weekdays.
stereohaven
Recognised Expert
Message 7 of 9
Re: Can I get 4k?
Or if you prefer, stick your phone number in here: https://www.dslchecker.bt.com/
In the VDSL section you want to see at least 44mb in the “Low” column.
McG
Message 8 of 9
Re: Can I get 4k?
I guess I can't have it then...
stereohaven
Recognised Expert
Message 9 of 9
Re: Can I get 4k?
Not currently no.
But, never say never, they may change their rules. I am in the same boat as you, hit a consistent speed of 47mb but my “Low” figure is 33mb so I cant order it.
