NickH161
Message 1 of 4
Can I watch BT sport on my sky Q and BT TV
Got broadband with BT and thinking of getting a BT TV box for 4K sport.
Question is can I watch BG sport on my sky Q box as well or will I only be able Watch on my BT TV
Moderator
Moderator
Message 2 of 4
Re: Can I watch BT sport on my sky Q and BT TV
Hi @NickH161 Check out Can I get BT Sport in more than one room?
It says "If you have BT TV and Sky in the same house, you can only have BT Sport on one of them."
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Distinguished Guru
Distinguished Guru
Message 3 of 4
@JohnC2 Looking at the current 4aug2017  BT Consumer Price Guide there is a tariff listed for   BT sport Multi Platform  which  describes the addon as allowing you to watch BT Sport on BT TV and Sky TV.
NickH161
Message 4 of 4
Guessing there would be a charge for that?
