sjp15991
Message 1 of 14
Can't log in on Chrome - error message WJ900 but does work on IE
Hello
I don't use IE at all so using it long-term just for BT Sport is not a real solution. Can someone tell me why I am getting this error message (it just says login failed and gives me no more info)? I have seen on other posts mention of going onto your phone and looking for the number of devices but I also don't seem to have a manage my devices or similarly worded thing on the settings tab on my phone - help seemed the most likely but that also did not work. My phone is an Iphone also.
Thanks for any help given!!!
13 REPLIES 13
DarrenDev
BT Sport Expert
Message 2 of 14
Re: Can't log in on Chrome - error message WJ900 but does work on IE
Hey @sjp15991 . WJ900 is a catch all meaning that we couldn't log you in, but don't specifically know why.
The most common cause of this is cookies - if you clear your cookies in Chrome, this will usually resolve the issue.
Deleting registered devices won't help, so I definitely don't recommend that.
sjp15991
Message 3 of 14
Ah you are right, so I did that and it worked last night but then after about 24 hours of me using my computer again it has now stopped working again. Surely I don't have to clear them every time I use the player!?
DarrenDev
BT Sport Expert
Message 4 of 14
Unfortunately @sjp15991 we've discovered that some parts of bt.com are setting very large cookies which break the BT TV player.  We're trying to find a solution for this, but in the meantime I'm afraid you're going to need to clear your cookies each time it happens. Sorry about that.
sjp15991
Message 5 of 14
I've actually now reset cleared my cookies and it is still not working! I was hoping to watch the football in 45 mins!
Is there a solution planned for the cookies issue long term?
and do you have a solution for my immediate login problem? (I am still getting the same code after following instructions here - https://support.google.com/accounts/answer/32050?co=GENIE.Platform%3DDesktop&hl=en)
Please help ASAP
sjp15991
Message 6 of 14
I should say that it also does not work on IE either anymore, and I have cleared all the history there as well.
DarrenDev
BT Sport Expert
Message 7 of 14
WJ900 is a BT TV error, but your account only shows as having a BT Sport subscription. Try the BT Sport player at www.bt.com/sport/watch/ and you should find it'll work OK.
sjp15991
Message 8 of 14
Excellent thank you, I had no idea this existed, is this gonna solve the long term cookies problem as well?
DarrenDev
BT Sport Expert
Message 9 of 14
There is no cookies problem for BT Sport. I'm not sure why I hadn't picked up on your lack of TV subscription before - I just saw WJ900 and responded with the answer to that. 🤦‍
sjp15991
Message 10 of 14
Has this still not been resolved? I am able to use this go-around for live football as described above but its much more difficult to watch other older episodes/highlights etc without going to player.bt.com and frankly since I am a paying customer I would like to use the proper player website.
