dmc1980
Message 1 of 9
Cancel BT Sport online?
Does anyone know if there is anyway to cancel BT Sport online as am unable to do it over the phone? Checked all over but can't seem to find any links or where to cancel?
Tags (2)
8 REPLIES 8
-Richie-
Expert
Message 2 of 9
Re: Cancel BT Sport online?
Not yet no, you can ask a friend or relative to call for you, they'll need to pass validation so it would be best if you were there at the time of the call.
Moderator
Moderator
Message 3 of 9
Hi @dmc1980  thanks for your PM and sorry you are still having difficulty getting the BT Sport canceled. I've sent you a Private message explaining how you can contact the forum moderation team and we will be happy to help you with this.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Moderator
Moderator
Message 4 of 9
Hi @dmc1980  thanks for sending over your details. The order to cancel the BT Sport has now been placed for you.
Cheers
John
kirstilong
Newbie
Message 5 of 9
Hi
I note that you are a helpful chap.
Would it be possible for you to cancel my BT Sport subscription.
I haven't used it once!
Moderator
Moderator
Message 6 of 9
@kirstilong Welcome to the community and thank for posting, I'm sorry to see that you want to cancel your BT Sport can you try the helpdesk on 0800 800 030 and they'll be able to help you with that request.
kirstilong
Newbie
Message 7 of 9
Hi thanks for replying
oh right, could you not assist me like the OP
To be honest even though i have a landline at home i dont actually have a phone to plug in the socket!
Its purely for broadband
I appreciate any help you can give
Moderator
Moderator
Message 8 of 9
Hi @kirstilong the number is also free to call from UK mobiles, the original poster wasn't able to do it over the phone so we helped in that instance.
The moderation team are really busy at the moment so you'll get this done much quicker if you give them a call.
kirstilong
Newbie
Message 9 of 9
Ok, i will do this later but do you know the reason why this cannot be done online?
Its 2019,  BT will gladly let you sign up for anything that creates revenue but won't allow you to cancel online?
