Message 1 of 3
Cannot get BT Sport 2 or 3. on my T2110 box Using NETGEAR Router.
Hello,
I have a T2110 box from BT, and I use a NETGEAR Router model D6220, I can get BT Sport 1 on my T2110 box but cannot get BT Sport 2 or 3, on the setup for the NETGEAR Router there is a box witch is tick saying allow BT TV. I can also get Sky Sport main event on my T2110 box, so can not understand why I cannot get BT Sport 2 or 3.
Any Help with this problem would be great.
Matthew
2 REPLIES 2
Guru
Message 2 of 3
Re: Cannot get BT Sport 2 or 3. on my T2110 box Using NETGEAR Router.
Hi, have you ever been able to watch BT Sports 2 & 3? What BT TV package do you have?
Stew
Message 3 of 3
Hi Stew,
Thanks for your reply, I am happy to tell you that the problem is now fixed.
Thank you
Matthew
