Moderator
Moderator
Message 11 of 13
Re: Casting not included in BT Sport subscription
Hi @medical154 and thanks for posting.
I'm sorry there's been some confusion over the order. @NeilO was in contact with another department to get the order placed. He'll be in touch shortly to sort out any recontract issues.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
medical154
Newbie
Message 12 of 13
Hi David,
Thanks for this. NeilO has been in contact and is taking the matter in hand - so hopefully it will all get sorted now.
Thanks again to both of you for your help.
mrk75
Message 13 of 13
Similar issue for me. I had the BT Sport app previously with a broadband package and could cast via Chromecast.
We switched broadband suppliers but I took out a BT mobile contract because it gave me BT Sport via the app. I assumed I would be able to case and don't recall seeing any information to the contrary.
I now find I can't cast and this appears to be slightly underhand in that there was no clear warning regarding this.
Has anyone found a way to adjust one's subscription to obtain casting functionality? If not, I might just quit the contract at this stage.
