Dogegg
Newbie
Message 1 of 2
Catch Up or only live?
Just got BT broadband and so would be watching on the PC. Is there a catchup feature or do you have to watch everything live? Quite fancy watching some NBA but most are on at 1am.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Catch Up or only live?
Hi Dogegg,
There is a catch up feature for the BT Sport service however the content on this varies and I can't see any NBA games on there at the moment, if you login to here you can see what's available.
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
