Distinguished Expert
Message 11 of 25
Re: Change Sky Viewing Card
Yes, as long as you are by your box so they can get the card number and the box serial number.
To say thanks for a helpful answer, please click the white star
robo567
Message 12 of 25
ok I will try that if wife will let me take card out as she is watching telly now
Message 13 of 25
don't need to take card out just go to services and you should see details which you will be asked for when you phone sky
robo567
Message 14 of 25
how can they pair it if its not in the box you want to pair it with
robo567
Message 15 of 25
I have to take it out and swop them over do I not?
Message 16 of 25
sorry though card was already in the box  yes you need in box and if you try and select a channnel it will probably pop up with phone number to call
robo567
Message 17 of 25
it just says wrong card as I have different boxes ones sky+hd and the other is a digibox
Message 18 of 25
Both sky boxes?
robo567
Message 19 of 25
I changed the cards and then went to sky and got the channels put on the cards and it worked but I lost HD on the HD box aaaaaaahhhhhhhhh
whitewitch1
Message 20 of 25
Can someone help me how do I get bt sport to change my viewing card number, I pur it on my sky+ box instead of my standard sky box.
