robo567
Message 21 of 25
Re: Change Sky Viewing Card
just swap over the cards then go to sky.com and get your channels put on the cards, the numbers will come up. that's if you have a sky ID
Nelix01
Message 22 of 25
You can do this online at the follwoing website:
http://www.skyviewinghelp.com/
_________________________________________________________
BT Infinity Option 2 76Mbps Down 17Mbps Up
YouView Unlimited Extra Channels
Message 23 of 25
I used that link but it was basically sky checking the multiroom boxes were still in same place and in one home.  don't think it was for swapping cards ...unless you have tried it
Nelix01
Message 24 of 25
I haven't relied it myself but I believe it will work for swapping cards around boxes
Message 25 of 25
well if someone does try it and whatever the outcome would be good if they posted results  still think it is just sky checking their records as message only appears on multiroom box not main box from my experience anyway
