Anonymous
Not applicable
Message 1 of 9
Channel 465 in HDR
Hello.
I took a pause when the football season ended on my BT sport ultimate.
I restarted it and it's come on this morning.
However, nothing in my setup has changed but on going to 465 and the test footage it says with a banner my TV doesn't have HDR and to go to 433.
I never had this problem before and yes it is fully HDR compatible.
What's going on??
Thank you
8 REPLIES 8
Anonymous
Not applicable
Message 2 of 9
Re: Channel 465 in HDR
Update..
The TV says it's getting the HDR signal and I can tell from the Bertie Basset colour palette is definitely on..
So why the banner saying it's not?
Anonymous
Not applicable
Message 3 of 9
 So here it is. The error message I get despite the TV acknowledged a HDR signal on bottom right..What's going on?
Message 4 of 9
I occasionally see that message sometimes even after it has switched to HDR on the tv - it usually goes after a few seconds.
Usuaully occurs only the first time I use the box for a while.
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Anonymous
Not applicable
Message 5 of 9
Thanks for the reply.
Do you know if they've tweaked the TV picture settings recently as I'm seeing notable differences of improvement in HD channels.
I still have to turn off the frame rate matching setting though as I see judder on the TV picture despite all enhancements off on the TV.
Message 6 of 9
There was a discussion about the frame rate issue - I think if https://community.bt.com/t5/YouView-from-BT/BT-TV-Box-Pro-comments-questions/m-p/2243663#M67346
I've not noticed any changes to HD but I tend only to use the UHD channels.
Anonymous
Not applicable
Message 7 of 9
Forgive me for asking but what's in uhd apart from channel 465??
Do you mean Amazon and Netflix content?
Message 8 of 9
433 is UHD - 465 is UHD/HDR.
Anonymous
Not applicable
Message 9 of 9
Happy to report thanks to an intervention by Moderator Dave the issue seems resolved.
I had all the correct settings in harmony with my Philips Ambilight TV and my BT pro box with one exception - we changed it to 10bit from 8bit and ensured hdmi frame rate matching was turned off.
Thanks Dave, and everyone else who contributed. 🙂
