timbo1963
Message 21 of 42
Re: Chromecast sound problem ADVERTS!
Hopefully this will be resolved ASAP as it’s really bad. Come on BT do your stuff!
TheRealBudski
Message 22 of 42
Same problem with the rugby this afternoon
timbo1963
Message 23 of 42
Yep me too. So annoying, I’ve only had my tv a week and thought it was faulty!
BT Sport Expert
BT Sport Expert
Message 24 of 42
An update: we are able to reproduce this ourselves and are working with Google to find a fix.
BT Sport ExpertJamesD
Show your appreciation!
Click on the thumbs up next to a reply to say thanks
Kudos”
I am a BT Employee and an expert on BT Sport queries. I am here volunteering my own time to give advice and help, where I can, primarily with BT Sport App and website queries. Go here for more info.
Brads42
Message 25 of 42
Good news, sounds promising.
Message 26 of 42
Good to hear, look forward to hearing of a fix
kaize
Message 27 of 42
Hi James,
Hows the fix coming along? Is there any updates to app coming up?
BT Sport Expert
BT Sport Expert
Message 28 of 42
An update for you:
  • Google have accepted the case and have someone working on it - when we know more about their fix we'll post an update here. We've seen them get some fixes out pretty quickly in the past - and this is easily reproduced which is massively helpful for them figuring out what's going in.
  • In the meantime we're disabling the 'digital ad insertion' for this weekend on Chromecast: for live events on the Sport Digital streams we substituate 'broadcast ads' i.e. the adverts in the normal TV channel output which are the same for all viewers, with digital equivalents which can be unique per viewer. If you have a white blob at the top-right of the picture during an advert it's broadcast ad, if you don't it's a 'digital' advert. Google appear to have changed something in their latest hardware/software which causes this sound problem when the substitution happens.
Kudos”
benshaw627
Message 29 of 42
I have to say that the adverts are very well synced, normally with digital adverts I get the odd one cut off but they seem perfect times for the break between the broadcast, I had no idea I was seeing digital adverts but that’s explained another issue I was having which is  why are the lip sync on the adverts out of sync but the broadcast lip sync fine.
benshaw627
Message 30 of 42
Has the change in the broadcast effected the frame rate as the picture looks like it did on chromecast before you added hd to the app
