Same problem with the rugby this afternoon
An update: we are able to reproduce this ourselves and are working with Google to find a fix.
BT Sport Expert | JamesD | |
Did you get the help you needed? Help others by clicking on ‘Mark as accepted solution’ | Show your appreciation! Click on the thumbs up next to a reply to say thanks | Help guide to using the community? Click below |
I am a BT Employee and an expert on BT Sport queries. I am here volunteering my own time to give advice and help, where I can, primarily with BT Sport App and website queries. Go here for more info. |
An update for you:
I have to say that the adverts are very well synced, normally with digital adverts I get the odd one cut off but they seem perfect times for the break between the broadcast, I had no idea I was seeing digital adverts but that’s explained another issue I was having which is why are the lip sync on the adverts out of sync but the broadcast lip sync fine.
