dapg39
Message 1 of 4
Download usage
I have BB only & infinity is not yet in my area, so looking to stream online.
Currently have 40GB allowance and use on average 18GB.
Any ideas how many GB streaming will be for a match on my PC?????
Currently work away so will not see all 38 games.
Many thanks
3 REPLIES 3
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: Download usage
It depends upon what bitrate BT use for transmission. They could choose a low bit rate eg 400Kbs or  reasonable quality 1800kps  or a higher quality 2500kbs- 3500kbs.
So if the lowest quality was used then you would probably accomodate it within your allowance otherwise if the better quality streams were used you would exceed it unless you only watched the occasional game.
dapg39
Message 3 of 4
Re: Download usage
Maybe be a better idea to pay the £10 for the viewing card then at least I won't be stung at the end of the month??
Community Manager
Community Manager
Message 4 of 4
Re: Download usage
Hi Dapg39,
Thanks for the post and welcome to the forum.
Streaming on the BT Sport App and streaming premium content on btsport.com  won’t  count towards your BT broadband usage limit.
If your broadband isn't with us, or you watch BT Sport via a mobile data connection, that may count towards any allowance you have.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”Kudos”
