Message 51 of 61
Re: EPG not correct for ch 465 today
I see the Milan derby is also scheduled for Ultimate next Saturday again with the 4k coverage starting 15 minutes after the programme on BT Sport 1.
With there being a lot of sport at the same time I can’t record both just in case, so is it actually going to be in 4K or should I set my recording for BTS1?
Message 52 of 61
I'll be setting mine for BTS1 after missing out on the last supposed game being on 465. Unfortunately I realised much too late it hadn't been recording.
Message 53 of 61
It is still showing on my box - but BT sent out an amendment this afternoon which seems to remove the Serie A programme for 3rd September.
It wasn't exactly clear.
Fibre 2 Unlimited using BT Hub 6A with BT TV Box Pro (UHD/HDR).
Message 54 of 61
What do you mean when you say BT sent out an amendment? The latest info I have still shows the match on Ultimate in HDR.
Message 55 of 61
It isn't clear as the programme was at 5.15pm - but seems to be missing now
Message 56 of 61
What is that from?
Message 57 of 61
DM sent
Message 58 of 61
It has now gone from the BT EPG.  I think really, if it was on, the the synopsis should indicate that the match was being joined in progress as it is a 5pm kickoff - but can not be shown in the UK until 5.15pm.
Message 59 of 61
Thanks for this can't say I'm surprised I wonder if Inter v Torino will be/is being scheduled for the 9th only to disappear!?
Prior to Sky getting Bundesliga rights we used to get the 'Topspiel' Saturday evening game in UHD so it's not unheard of for BT to show games from a European league in UHD, I wonder why Serie A seems to be proving tricky?
Message 60 of 61
Just checked my work messages and found that the reason the matches were being cancelled from Ultimate at the last minute was due to source stream issues. We had hoped to offer the matches on Ultimate, but we were unable to decode the audio in the test streams they were sending us.
They were scheduled for Ultimate in the hope the audio would be fixed, but with it still not being fixed the day before each match, they were then being removed.
I don't know if the issue has been fixed, or if any subsequent Serie A matches have been shown on Ultimate?
