andym2019
Message 1 of 6
Error IPC6023 on tv Error VC011 on laptop
Getting the above errors on my tv and laptop so cant actually watch anything.
Tried getting in touch with BT help - apparently a specialist will phone in 1 - 2 working days - not ideal when I have no TV to watch..
Anyone able to help?
Thanks!
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Error IPC6023 on tv Error VC011 on laptop
Hi @andym2019,
Welcome to the Community and thanks for taking the time to post.
Sorry to hear that you are having problems watching BTTV.
This could be a bit of a tricky case and that's why it has been sent to a specialist. Normally the IPC6023 error means that the broadband connection is not getting the BTTV Set-top-box.
Are you noticing poor broadband performance on other devices?
Are you accessing the BTTV Everywhere online player or BT Sport player?
Has the service ever worked before?
Matt
andym2019
Message 3 of 6
Hi Matt,
Many thanks for your reply.
The broadband is working perfectly for everything bar BT TV.
I have previously been in touch with BT and they sent me a new top box - unfortunately with the same result. Could it be a problem with the Home hub?
I was attempting to reach the BT sport player, and yes it has worked previously.
Moderator
Moderator
Message 4 of 6
@andym2019
I know you have been sent a new box but can you try a factory reset on the BTTV box?
Are you able to watch the likes of Netflix or iPlayer on the BTTV box?
I've sent you a Private Message with details on how you can get in contact with the mod team.
Matt
andym2019
Message 5 of 6
Hi Matt,
I have reset the top box and its the same result.
Netflix and iPlayer both work as expected.
I'll get get in contact via private message.
Moderator
Moderator
Message 6 of 6
Perfect thanks for checking.
Cheers
Matt
