Message 1 of 5
Error message - cast limit
Hi - I’m trying to cast from BT TV app (not BT Sport) & get error AP928 number of devices exceeded, even thought it shows I have fewer than the 4 allowed. What should I do?
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Error message - cast limit
Hi @Fbedin, welcome to the community and thanks for posting if you go into settings and device management on your app can you see how many devices are currently registered?  With the BT TV extra app you can have up to four devices registered and watch programmes on two of these devices at the same time. Post back and let me know how you get on with that check?
Message 3 of 5
Thanks Neil -
It’s showing 3 devices registered, the first is the one I’m trying to use and number 2 & 3 were last used on 29/05/2019 & 12/12/2018
Moderator
Moderator
Message 4 of 5
@Fbedin thanks for trying that for me, we'll need to get a fault reported for that. I'll send you a private message in a few moments so you can send over your details.
Message 5 of 5
Thanks Neil - much appreciated! Finlay
