chrisg88
Message 1 of 6
Errors GJ999, AJ999, WJ999 when trying to log into BT TV Player app/website
Hi
I keep getting the same errors each time I try to log into the BT TV app or website, always ending in 999 (GJ999 on Android, AJ999 on iOS, WJ999 on the web). I have tried to submit a fault online via BT.com but the new 'troubleshooter' system just leaves unsubmitted faults each time I get to the last step. I then go in to try and resume the fault report and it just hangs.
Can anyone advise how I can get this resolved or raised as a fault?
Thanks!
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Errors GJ999, AJ999, WJ999 when trying to log into BT TV Player app/website
Hi @chrisg88 Thanks for posting, I'm sorry to see you're getting errors when trying to login to the BT TV player. I've sent you a Private Message with details on how you can get in contact with the mod team and we'll be happy to get this looked into.
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 3 of 6
Hi @chrisg88
Thanks for sending in your details via private message.
I have made a few changes to your account in the background. Can you try and access the APP or Online player and let me know if the issue is now fixed?
Matt
Community ModeratorMatt
Kudos”Kudos”
Moderator
Moderator
Message 4 of 6
Hi @chrisg88,
I hope you are keeping well?
I sent you a private message last week to let you know that we had made a few more background changes. When you get a minute can you test the service and let me know if you get the same error message?
Cheers
Matt
Kudos”Kudos”
chrisg88
Message 5 of 6
Hi Matt
I actually got around to testing it last night and it now works perfectly. Thanks very much for your help!
Cheers
Chris
Moderator
Moderator
Message 6 of 6
That's mighty @chrisg88 glad to hear the fault is now fixed.
Matt
Kudos”Kudos”
