forumprowler
Message 1 of 22
FreeSports
Why can't I get FreeSports on my BTTV? I've ried retuning etc but still nothing. Any help appreciated.
Cheers
FP
21 REPLIES 21
Moderator
Moderator
Message 2 of 22
Re: FreeSports
Hi @forumprowler welcome back sorry you are having difficulty getting Freesports on your BTTV
I appreciate that you may have already checked this but will you switch to Channel 64 and see if you get any error message.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
forumprowler
Message 3 of 22
Re: FreeSports
Hi John,
Thanks for getting back. I'm fairly sure I've checked that but I'll take another look and get back to you.
Cheers
FP
Moderator
Moderator
Message 4 of 22
Re: FreeSports
Hi @forumprowler Thanks and do post back and let me know how you get on.
cheers
John
Kudos”Kudos”
forumprowler
Message 5 of 22
Re: FreeSports
Hi again John,
Nothing on 64. Over to you....
Cheers
FP
garybs29
Message 6 of 22
Re: FreeSports
Check your postcode here - https://www.freeview.co.uk/channels-at-your-address
May be a case of not being available in your area
Moderator
Moderator
Message 7 of 22
Re: FreeSports
Hi @forumprowler it may be that it's not available in your area as @garybs29 has mentioned.  You can find further information on a Previous Forum Thread that may be useful.
Cheers
John
Kudos”Kudos”
Dan2234
Message 8 of 22
Re: FreeSports
Freesports is on a HD mux  broadcasting in DVBT2 you will need a Freeview HDTV or BTTV HD box to pick it up
forumprowler
Message 9 of 22
Re: FreeSports
Hi @Dan2234,
Thanks for the reply. I have a BTTV HD box but nothing on 64. I've had a look at the link posted by @garybs29 but it doesn't look like my post code is on there so I guess it's not available to me yet. Thanks all for the replies.
Cheers
FP
JamieHeavens
Message 10 of 22
Re: FreeSports
I’ve just retuned my BT box - the Channel 64 is not available. However when I do a postcode check it says the channel is available with a HDTV BT box which I believe I have. Any reason why it still won’t work 🙈
