Moderator
Moderator
Message 11 of 14
Re: Hi I have the same problem has a number of people, I cant get BT sports
Thanks for posting back @Ian31,
@JohnC2 isn't about at the moment but I'll make sure he gets your message Smiley Happy
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Ian31
Message 12 of 14
Thank you Robbie.
Ian
Moderator
Moderator
Message 13 of 14
Hi @Ian31 Thanks for the update. I hope all is still working ok for you and if so are you happy for me to close this case now?
Cheers
John
Community ModeratorJohnC
Kudos”
Ian31
Message 14 of 14
Hi John
Its is a lot better and I am very pleased, thank you so much for your help.    5 stars
Ian
