Lotz123
Newbie
Message 1 of 2
Iphone xs max full screen for enhanced player matches
How do you change from the enhanced player for games like champions league and the premier league to a normal player. Only the normal player can be double tapped to full screen on an iphone xs max, ive tried the previous solution of turning on airplane mode once into the app but i run into the problem that it cannot play the videos it just shows error messages.
1 REPLY 1
BT Sport Expert
BT Sport Expert
Message 2 of 2
Re: Iphone xs max full screen for enhanced player matches
Hi Lotz123 - you will be given the option of watching on the Standard player (and thus able to watch in full screen mode) if you are connected to wifi. If you open the player while on mobile data then you will be directed to the Enhanced player, with all it's great features, automatically.
Adding full screen mode to the Enhanced player is something we're working hard on for the new season.
BT Sport expertKitH
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on BT Sport queries. I am here volunteering my own time to give advice and help, where I can, on BT Sport queries. Go here for more info.
