jaybeetoo
Message 1 of 3
Keep being asked to enter a PIN for channel 430
BT asked me to do a factory reset on my YouView box.
Since doing it, I keep being asked by Parental Controls, to enter a PIN every time I go to channel 430.  It doesn't happen on any other channel.
I have turned off parental controls and turned off PIN required to authorise payment but I'm still asked for a PIN on 430.
Any suggestions please?
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Keep being asked to enter a PIN for channel 430
Suggest you try again now .  I suspect that it will not ask for a Pin now.
I notice that the program scheduled (The Book of Manning) on BT Sport 1 between 6:30pm and 8pm is rated 18 on the guide. As it is before the watershed it would be expected that a PIN would be requested to allow viewing.
jaybeetoo
Message 3 of 3
Thank you!
