ozsat
Recognised Expert
Message 1 of 7
NowTV Smart Box display bug
There is an odd on-screen graphic appearing on the 4K/HDR stream on the Now TV Smart Box.
It is just above the 'BT Sport Ultimate' dog and (at a guess) appears to display the stream rate.
When you load the app it increased the displayed number and then alternates between 0 and 27.
I've checked the Ultimate streams elsewhere and the text does NOT appear.
Fibre 2 Unlimited using BT Hub 6A with BT TV Box Pro (UHD/HDR) via 5GHz WiFi.
6 REPLIES 6
DarrenDev
BT Sport Expert
Message 2 of 7
Re: NowTV Smart Box display bug
We're currently trialling the BT Sport app on a couple of new platforms, and that indicator is there as part of that trial. It shouldn't be appearing on NowTV though, so thanks for raising it - I'll get that sorted ASAP.
ozsat
Recognised Expert
Message 3 of 7
The box is still appearing on the Now TV app - any news of it being removed?
DarrenDev
BT Sport Expert
Message 4 of 7
It was decided that it didn't warrant an urgent release - it'll go into whatever the next scheduled maintenance release is. I've asked for a date on when that'll be.
ozsat
Recognised Expert
Message 5 of 7
no - not urgent.
ozsat
Recognised Expert
Message 6 of 7
This has been fixed in past couple of days.
DarrenDev
BT Sport Expert
Message 7 of 7
Yes, the update was released on Monday evening. 😀
