gilera
Message 1 of 5
Player stops at Advert breaks
Does anyone know what can cause the player to stop streaming when the advert breaks come on. I have to refresh page and reselect the player each time.
4 REPLIES 4
BT Sport Expert
BT Sport Expert
Message 2 of 5
Re: Player stops at Advert breaks
Hi gilera
Are you running any ad blocking software?
If so try turning that off - pls post if that doesn't resolve it
Community ModeratorJamesD
Show your appreciation!
Kudos”Kudos”
I am a BT Employee and an expert on BT Sport queries. I am here volunteering my own time to give advice and help, where I can, on BT Sport queries. Go here for more info.
gilera
Message 3 of 5
Yes i do run an adblocker, will try turning it off at weekend moto GP and see what happens, thanks.
BT Sport Expert
BT Sport Expert
Message 4 of 5
For your info, we are looking to workaround this - so that you can have ad blocking and stream BT Sport at the same time. I'll reply when we've managed to sort that out but until then I suspect for big events you will have to disable ab blocking
Aplologies for the inconvenience in the meantime!
James
Kudos”Kudos”
gilera
Message 5 of 5
Thanks for taking an interest.
