Scottiemcd
Message 1 of 12
Problem getting a at Sport on TV
Need help or guidance on this one. Recently upgraded my package to fibre optic unlimited and until tonight I had no BT Sport channels listed (overcame this by reinstalling channels and now they are all ther) when I select any of the channels it tells me to subscribe when as far as I am aware I have already, there is no activation option in my but when I go into the BT sport section, but I am pretty sure I did that at the beginning when I first got the original BT package prior to upgrading. I can access BTSport online through the app, but want to watch it on TV. Been scouring the site for ages looking for help with no joy.
Thanks Scott.
11 REPLIES 11
Distinguished Guru
Message 2 of 12
Re: Problem getting a at Sport on TV
You need to follow the instructions to subscribe to get it activated
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Scottiemcd
Message 3 of 12
What instructions?
Distinguished Guru
Message 4 of 12
What appears when you go to the sports channel eg BT sports 1
Helpful Post?
Scottiemcd
Message 5 of 12
It just comes up tell me I need to subscribe, which I believe I have already.
Distinguished Guru
Message 6 of 12
Is this on SD or HD
Helpful Post?
Scottiemcd
Message 7 of 12
Just the normal channel, not HD
Scottiemcd
Message 8 of 12
Just tried it again and I first got "set up channel" followed by the "loading" screen which takes a 2-3 minutes then this time it says, "there's a problem showing this channel so we need to talk to you. Error cod BTV-251
Telecom89
Recognised Expert
Message 9 of 12
Have you tried changing to another channel and then back to the 'problem' channel?
I've seen a similar issue when moving channels from an old to a new YouView box.
Distinguished Guru
Message 10 of 12
If after completely rebooting the box and router and it still doesn't work then you probably do need to contact them.
I assume you are using a BT Hhub?
Helpful Post?
