daveybawden
Newbie
Message 1 of 6
Re: No BT Sport on Youview Box
I am having exactly the same problem - please advise?
5 REPLIES 5
cr4ckf0x5teve
Message 2 of 6
I've got to wait for an engineer visit to resolve whatever my issue is.  Once resolved I'll post up so that it might help/inform others.
Moderator
Moderator
Message 3 of 6
@daveybawden I've started your own thread to ensure there is no confusion with the original posters issue as this was still ongoing.  Are you getting any error messages when you try to view sport?
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
daveybawden
Newbie
Message 4 of 6
It just asks me to log on to bt website to upgrade....I was under the impression I had already upgraded. Username is Edited by mod
Moderator
Moderator
Message 5 of 6
@daveybawden
It's best not posting usernames or personal information that could be used to access your account details so I've edited this out.  It sounds like you don't have a BT Sport subscription to view this on your BT TV, if you follow the website instructions it will explain what you need to do. If you've upgraded your broadband or TV subscription the BT Sport needs to be added separately.
Neil
Kudos”Kudos”
Moderator
Moderator
Message 6 of 6
Moved:
