Theola
Message 1 of 4
Re: "BT ID Correct but BT Sport is not part of this account".........I have BT Sport?
I have exactly the same problem since Nov 2014 !
Will email you as please, thanks
3 REPLIES 3
Theola
Message 2 of 4
John,
Don't get an option to contact the mods when I click on your username ?
What am I doing wrong ?
chime
Message 3 of 4
@Theola wrote:
John,
To see a contact link you have to be invited to contact a mod.
Moderator
Moderator
Message 4 of 4
Hi @Theola and thanks for posting.
I'm sorry you're having poblems with the sports. I'm sure I can help you with this. Can you please drop me over an email with your details? You'll get the contact the moderators link in my profile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
