Message 1 of 12
Resetting devices on by tv app
Can some one explain how to reset devices on bt tv app as I only have one device registered and the app tells me I have to wait 30 days which is crazy. I’m on the current max 4 k tv package. Many thanks
11 REPLIES 11
Recognised Expert
Message 2 of 12
Re: Resetting devices on by tv app
This may sound daft but have you tried adding a new device?
I don’t think the wording on the device page helps, it sort of indicates the slots are locked unless you wait 30 days. The reality is you have to use up 4 slots on 4 devices then you would have to wait 30 days to change one.
Message 3 of 12
I’m trying to connect the app to a chrome cast device. But no success. Comes up with the message that I have to delete a device before I can add another and Thai have to wait 30 days.
Moderator
Moderator
Message 4 of 12
Hi @stewarttracey38,
Welcome to the Community and thank you for posting. I'll be able to help you get your devices reset on the BT TV app.
I have sent you a private message with instructions on how to contact me. You can access your messages via the envelope icon at the top right of the screen, or click on this link, Private messages
PaddyB
Moderator
Moderator
Message 5 of 12
Thanks for taking the time to send us in your details. I called you a few minutes ago sorry I missed you.
I was just calling to let you know that the issue should now be fixed but you may need to re-add your iPhone as well as the new Chromecast.
Please let me know how you get on?
Matt
Message 6 of 12
Re: Resetting devices on tv app
Hi Matt,
thank you for all your help the app has now reset devices and I can now stream to chromecast.....
Whilst I understand due to possible content supplier rights, its a shame that the end user can't just de register a device and add another as I for one have several Chromecast devices as well as the Bt TV app on my smart TV, this would make more sense and would not have to involve a back ground process that the end used does not have access to. It also saves on man power at your end and would have a better customer experience..
Anyway thanks for helping out.
Best regards
Stewart
Message 7 of 12
Hi,
I am experiencing the same issue with the BT TV app. I deleted one of my two devices and unable to add my chromecast.
Would be grateful for your help.
Moderator
Moderator
Message 8 of 12
Hi @Conny4  welcome to the forum and thanks for posting. When did you delete one of your devices?
Cheers
John
Message 9 of 12
Thanks for your reply John.
I deleted it on Saturday or Sunday and it said I could add another device on 18th November around 2pm.
Kind Regards
Jackie
Moderator
Moderator
Message 10 of 12
Hi @Conny4 thanks for getting back to me. I've sent you a Private Message withe details on how to contact the Mod team and we will be happy to help you get this sorted.
Cheers
John
