Jon1977
Message 1 of 23
Silverlight Issues
I have installed silverlight but when I try and view I get the message saying install silverlight. I refreshed, turned off and on again I even un installed and reinstalled and still nothing, I'm using windows 8.
22 REPLIES 22
homealone
Message 2 of 23
Re: Silverlight Issues
Same here. I do not think silverlight works on windows 8.
homealone
Message 3 of 23
I have  a solution. When it asks you to download silverlink again, click on the spanner symbol in the bottom right hand counter and select view on desktop. The player then works OK.
Message 4 of 23
Thankyou that worked but does not solve the issue, it needs to be looked at.
Jon1977
Message 5 of 23
Superstar, Thank you loads that's fixed it.
paul620
Newbie
Message 6 of 23
Im using windows 7 and i have silverlight already downloaded and i keep getting the download silverlight box on the viewing screen! I see above in the previous post for windows 8 users  to click the spanner symbol in the bottom right. What do i need to click? I would be very grateful for help, many thanks.
markyboy56
Newbie
Message 7 of 23
iget the same problem on windows 7
markyboy56
Newbie
Message 8 of 23
i click on spanner then desktop i then get error 6036
AllenWright
Newbie
Message 9 of 23
To solve this problem in internet explorer
Go to tools - Internet options - Programes - Manage add-ons
Then look for silverlight you will probably find it is disabled
Now highlight silverlight and click enable
you should now be able to watch BT Sports
Allen Wright
Electronics engineer
SDALY99
Newbie
Message 10 of 23
Also, if the Add on is enabled, and it still doesn't work....select Tools, and make sure ActiveX Filtering is not ticked in Internet Explorer....if it's ticked click it to untick it and all should work. Another thing is to add the site to your trusted sites as IE security settings could possibly stop Active X controls to work.
