Distinguished Guru
Distinguished Guru
Message 21 of 23
Re: Silverlight Issues
Ditching Chrome is a bit drastic if you prefer it as your default. You can easily switch another browser if you need Silverlight, or even use two at once. (I occasionally have footy on a Sky Go pop-up in IE while working with Firefox; alas BT Sport doesn't have a pop-up facility.)
siteguru
Expert
Message 22 of 23
https://community.bt.com/t5/Watching-BT-Sport-via-the-App-or/Workaround-for-Chrome-Silverlight-and-B...
Ian
http://www.siteguru.co.uk/be/ADSL2PlusForDummies.pdf - Having ADSL issues? Then read this PDF
Please don't click the star beside my name - too many stars makes you look like a swot!
Saeran
Message 23 of 23
No longer works:
With this version of Chrome:
I DO NOT want to use another browser - BT need to sort this out for 45-50% of people who use Chrome.
