ploppy
Message 1 of 4
Sound Barcelona Chelsea
Is it just me or is there something wrong with the commentators volume on this match?  Sounds like Flectcher and Hoddle are in a box (and I don't mean the commentators' box).    The rest of the sound is OK.  It's just the commentary.
3 REPLIES 3
Distinguished Guru
Distinguished Guru
Message 2 of 4
Re: Sound Barcelona Chelsea
The commentatotors did indicate  about 32 mins in that there were some sound issues that they were hoping to resolve
ploppy
Message 3 of 4
Thanks. I've since realised that the best way to raise issues is on Twitter. @BTCare. Loads of complaints on there.
Caher
Message 4 of 4
My sound kept stuttering and breaking up. It was just on this channel.
