Bunkerbob
Message 1 of 7
Sound breakup on recorded rugby highlights
Set Sky+ HD box to record Saints vs Falcons at 1am. Playback has sound breakup on commentary but commercial breaks are fine. I have experienced this problem before. Any suggestions?
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: Sound breakup on recorded rugby highlights
Hi Bunkerbob,
Welcome and thanks for posting. Sorry you're having problems with the playback sound quality. Do you get this with all recording or just the rugby? How is the box connected, is is scart or hdmi? Give us as much detail as you can and we'll try to help.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Bunkerbob
Message 3 of 7
Thanks for your reply. I have only noticed it on rugby recorded highlights so far, and I have recorded many other programs over the years. The box is connected with a scart cable. Interestingly, I watched matches live last weekend without a problem. I will record another highlights program this weekend and check if it is reproducible.
Bunkerbob
gridlad
Message 4 of 7
Hi there my wife has started to notice this problem on most ITV HD recordings. Have confrmed that the problem does not occur with direct HD broadcast.
The YouView box is less than a month old directly connec via a HDMI cable to a new Sony TV.
Did you follow this up with BT as requested.
Regards.
Jim
Tags (3)
Bunkerbob
Message 5 of 7
Yes, I recorded the Newcastle v London Welsh highlights broadcast at 4am on Bt Sport 1 and the playback was fine. I am wondering whether it is an HD problem. Next step is to record the same programme broadcast in the early hours in normal and HD formats to confirm. I will feedback when complete.
Bunkerbob
Message 6 of 7
I recorded a rugby highlights broadcast at 1am on Sunday, Jan 18th, on both normal and HD formats. On playback, the HD version was as described previously with sound breakup on commentary but not during commercial breaks. The normal version was fine.
Finally, I recorded a "Football Gold" programme broadcast on Sky Sports 1 at 3:30am on Monday, Jan 19th in both formats. There were no problems with either playbacks.
Bunkerbob
Message 7 of 7
Further to my post yesterday, I thought I would record a programme other than rugby highlights at around the same time and in both formats. So, I recorded Serie A review at 1:30am on Wednesday, Jan 21st. Replaying the HD format gave intermittent sound breakup on everything except commercial ads. i.e. even BT ads., while replaying the normal format version was fine.
