muggles
Message 1 of 6
The provided stream contains format errors VC034
When I start a BT sports app stream, the picture is green, runs for a few seconds then closes with the above message.
Works fine on my Samsung galaxy s3, my Google nexus tablet but not on my android box.
It was running fine until a recent update then this.
Hugely annoyed and disappointed as yet again BT are letting me down.
Please advise of a fix.
5 REPLIES 5
muggles
Message 2 of 6
Re: The provided stream contains format errors VC034
Did I ask the wrong question?
I'm paying for this service and not receiving it, just like the 60mb download speed I was promised but never received.
Please pay me the courtesy of responding to my question.
Thank you.
Moderator
Moderator
Message 3 of 6
Hi muggles,
Sorry about the delay getting back to you.  I'm afraid we don't offer support for the BT Sport app on android boxes.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
muggles
Message 4 of 6
Thanks for the reply, not to worry, my pc and laptop still work.
big_si_uk
Newbie
Message 5 of 6
Hi Muggles,
I had the same problem, and the same as you, received no support from BT, not even a reply to an email I sent them!
My workaround was to remove BTSport, then download an older version:
It works on my sumvision box, but remember to disable auto update :-).
Regards,
Si
PS Baffled how BT don't support android boxes, when it is the same as an android phone but without the mobile bit, just wifi?
Colin_London
Recognised Expert
Message 6 of 6
Why baffled? Many android apps are developed and tested only on certain devices. It's not as regulated an environment as iOS.
