muggles
Message 1 of 6
The provided stream contains format errors VC034
When I start a BT sports app stream, the picture is green, runs for a few seconds then closes with the above message.
Works fine on my Samsung galaxy s3, my Google nexus tablet but not on my android box.
It was running fine until a recent update then this.
Hugely annoyed and disappointed as yet again BT are letting me down.
Please advise of a fix.
5 REPLIES 5
muggles
Message 2 of 6
Re: The provided stream contains format errors VC034
Did I ask the wrong question?
I'm paying for this service and not receiving it, just like the 60mb download speed I was promised but never received.
Please pay me the courtesy of responding to my question.
Thank you.
Moderator
Moderator
Message 3 of 6
Hi muggles,
Sorry about the delay getting back to you.  I'm afraid we don't offer support for the BT Sport app on android boxes.
Neil
muggles
Message 4 of 6
Thanks for the reply, not to worry, my pc and laptop still work.
big_si_uk
Newbie
Message 5 of 6
Hi Muggles,
I had the same problem, and the same as you, received no support from BT, not even a reply to an email I sent them!
My workaround was to remove BTSport, then download an older version:
It works on my sumvision box, but remember to disable auto update :-).
Regards,
Si
PS Baffled how BT don't support android boxes, when it is the same as an android phone but without the mobile bit, just wifi?
Colin_London
Recognised Expert
Message 6 of 6
Why baffled? Many android apps are developed and tested only on certain devices. It's not as regulated an environment as iOS.
