munko123
Message 1 of 15
Transmitter strength
Can anyone tell me if I can receive BTsports via Btvision box. I know that I cant with a youview box. The info from BT is confusing to say the least. My local Transmitter is Scoval in the scottish highlands.
Thanks.
14 REPLIES 14
Guru
Message 2 of 15
Re: Transmitter strength
Thanks.
Hard to say for definite as I don't know the area, but according to ukfree Scoval is a Freeview Light transmitter which I don't think carries the COM6 mux necessary for BTS. So sadly I don't think so. Does the channel list on the transmitter link tally with what you can receive?
munko123
Message 3 of 15
Cheers for response been on this all day. Was told by BT that i cant but after the mis info that is being spouted by so called advisers thought someone here might have definative answer.
Guru
Message 4 of 15
Can you receive ITV4 and 4music?
munko123
Message 5 of 15
No mate but film4 has been added.
Guru
Message 6 of 15
Then I'm afraid you're stuffed as far as DTT is concerned. You may have to use the web interface. Or a Freesat from Sly installation would be another possibility, but you'd really have to want it to go that far.
munko123
Message 7 of 15
sky you mean, freesat card now a possibility and if there are more people in same situ as me I can see BT losing customers which I dont want, well not to murdoch.
Salcombedrewsy
Message 8 of 15
I'm also on a 'relay' transmitter so can't receive sport on my bt vision box. Only reason I placed the order for the tv package. One highlight being able to stream it via Apple TV although that kept rushing tonight
munko123
Message 9 of 15
This whole bts thing is becoming a joke. Cant understand why BT dont tinform their customers about this.
Salcombedrewsy
Message 10 of 15
Munko, have you spoken to India about this?! Not quite sure they understood about relay transmitters.
