Caher
Message 1 of 57
UHD picture v HD
Hi,
Just watching the Super cup on Ultimate and the picture are no better than HD. If anything marginally worse.
56 REPLIES 56
DirectorsScarf
Message 2 of 57
Re: UHD picture v HD
Same here, 4K looks naff, and the HDR stream via the app on my Samsung TV is waaaay too dark.
DirectorsScarf
Message 3 of 57
And why does it keep going pink on BT sport Ultimate??
Caher
Message 4 of 57
If I compare to say Netflix 4K there is a huge difference.
NigelB72
Recognised Expert
Message 5 of 57
You might want to check your settings then because i watched on BT Ultimate and there is a clear and noticeable difference between HD and UHD. I was flicking between HD & UHD and the difference was huge...  The occasional green screen was down to a technical issue on the UHD feed from the host broadcaster i think..
Caher
Message 6 of 57
Thanks. If say the settings are only on the UHD box and I've been through them a few times. As Amazon and Netflix give me an excellent picture it could only be the box.
NigelB72
Recognised Expert
Message 7 of 57
Are you watching Amazon and Netflix through the box or apps on the TV?
Caher
Message 8 of 57
Through the TV apps.
NigelB72
Recognised Expert
Message 9 of 57
You'll need to check your settings on the HDMI port and BT box then as the box might not be outputting UHD. Go to settings and I think it's display settings and change that to UHD.
NigelB72
Recognised Expert
Message 10 of 57
Check your TV instructions as well because not all TV's have all HDMI sockets UHD compatible
