Caher
Message 1 of 46
UHD picture v HD
Hi,
Just watching the Super cup on Ultimate and the picture are no better than HD. If anything marginally worse.
45 REPLIES 45
DirectorsScarf
Message 2 of 46
Re: UHD picture v HD
Same here, 4K looks naff, and the HDR stream via the app on my Samsung TV is waaaay too dark.
DirectorsScarf
Message 3 of 46
And why does it keep going pink on BT sport Ultimate??
Caher
Message 4 of 46
If I compare to say Netflix 4K there is a huge difference.
NigelB72
Message 5 of 46
You might want to check your settings then because i watched on BT Ultimate and there is a clear and noticeable difference between HD and UHD. I was flicking between HD & UHD and the difference was huge...  The occasional green screen was down to a technical issue on the UHD feed from the host broadcaster i think..
Caher
Message 6 of 46
Thanks. If say the settings are only on the UHD box and I've been through them a few times. As Amazon and Netflix give me an excellent picture it could only be the box.
NigelB72
Message 7 of 46
Are you watching Amazon and Netflix through the box or apps on the TV?
Caher
Message 8 of 46
Through the TV apps.
NigelB72
Message 9 of 46
You'll need to check your settings on the HDMI port and BT box then as the box might not be outputting UHD. Go to settings and I think it's display settings and change that to UHD.
NigelB72
Message 10 of 46
Check your TV instructions as well because not all TV's have all HDMI sockets UHD compatible
