Message 1 of 6
Unable to switch to new Sky Q viewing card.
Hi,
    Got Sky Q installed yesterday, went online to swap viewing card to new one for BT Sport, it says cannot do it with error:
Sorry, we can't provide BT Sport on this card. Please try a different card or click 'Cancel' to exit this journey.
I spoke to BT who said they couldn't do it either, then they said speak to Sky, who basically said if your Sky Q box is working and you are receiving all channels except BT, then it's a BT problem.
It would seem that neither company wish to take responsibility! I have to say that as BT is giving me the error, the problem does lie with them.
Any ideas?
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Unable to switch to new Sky Q viewing card.
Hi @heinzguderian,
Welcome to the community forum. Did you manage to get your viewing card details updated? If not, I'll be able to help you with this.
You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Message 3 of 6
Hi, I did thanks, eventually got through to a very helpful chap in technical support who was able to force the system to accept the number.
Not sure why they didn't say that in the beginning, but it's solved now!
Moderator
Moderator
Message 4 of 6
Hi @heinzguderian,
Thank you for posting back. I'm glad you manage to get that sorted Smiley Happy
Cheers
PaddyB
Message 5 of 6
I have been having the same issue and nobody at BT can sort it. How did the force through the change because nobody at all can help me change it
Newbie
Message 6 of 6
I am having the same issue. Bt kept saying the addresses have to be exact otherwise it won't swap it? Not sure I believe this though!
