HornetMaX
Message 1 of 14
VC 019 - found a NEW solution !!
Hi all,
I was stuck on VC019 error with BT Sports on my PC (while it was woprking fine on a MacBookPro and the App was working fine too on my Android phone). I followed all the step in the procedure described in the sticky post in this forum (Top tips for Silverlight Issues with watching BT Sports) but without any result.
Then I recalled that for technical reasons I had to force monitor detection for Intel HD graphics and to do so I had to make Windows 7 think I have 2 displays (even if I only have one), the second display being an extension of the first one.
So bottom line, windows thikns I have 2 displays and this seems to confuse Silverlight.
As soon as I switch back to single display (press Windows + P and select "Computer only" in the pop-up), BT Sports work !!
So if you do have multiple displays (or if like me you're making Win think you have multiple displays), switch to single display to watch BT Sports.
@Forum moderators: you may want to make this sticky or to add this in the existing sticky post describing how to fix issues.
MaX.
13 REPLIES 13
Moderator
Moderator
Message 2 of 14
Re: VC 019 - found a NEW solution !!
Hi HornetMaX,
Thanks for posting, great advice Smiley Happy
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
litchy66
Newbie
Message 3 of 14
You are a star Max. I've spent weeks messing around trying to solve this problem.
HornetMaX
Message 4 of 14
It was driving me crazy too, then all of a sudden the doubt came and ...
MaX.
X0X
Newbie
Message 5 of 14
I was also having the VC019 issue and eventually I worked out it was because I'd disabled my laptop speakers (to play to a bluetooth device). Haven't seen this posted anywhere so hopefully it will help somebody. It would be good if a mod could collate these...
Cumbrian
Message 6 of 14
Anyone know how to sort this out on Windows 8.1.tried everthing mentioned on the forum but nothing works.i can see everything on my tv via wifi exept bt sport.come on bt sort this out.Cumbrian
Distinguished Expert
Message 7 of 14
Try a different browser. Chrome works best for me on Win 8.1
To say thanks for a helpful answer, please click the white star
Distinguished Guru
Distinguished Guru
Message 8 of 14
I couldn't get any joy with W8 on any browser, despite trying every known cure. Eventually found one which I hadn't seen reported by anyone else; in case you missed it have a look here.
Cumbrian
Message 9 of 14
Get no joy with any browser,pottyperson tried your idea,that didn't work either.Why is it only BT sport this happens to.looks like i will have drag a HDMI cable across the room to watch bt sport.i wish they would get this sorted.i assume they are aware of it.Thanks everyone.Cumbrian
cmbrooks7
Newbie
Message 10 of 14
HELLO I HAVE HAD THIS VC 019 ISSUE FOR SOME DAYS NOW
I NEED HELP TO FIGURE OUT HOW TO RESOLVE THIS PROBLEM.
CAN SOMEONE EXPLAIN TO ME WHY THIS HAS SUDDENLY HAPPENED AFTER THE ONLINE PLAYER HAS BEEN WORKING PERFECTLY FOR ALMOST 6 MONTHS?
I HAVE A MACBOOK PRO AND OFTEN USE THE SPLIT SCREEN (via HDMI CABLE) FEATURE.
PLEASE HELP!! ANY HELP WILL BE GREATLY APPRECIATED
