Message 1 of 12
Hi i can get bt sport on4g but not on wifi it say error vc003 out of eu but i am not i am in uk
11 REPLIES 11
Message 2 of 12
Re: VC003
Welcome to this user forum.
Which mobile phone are you using? Where in the UK are you located?
Recognised Expert
Message 3 of 12
Re: VC003
Until someone more qualified arrives, can you advise whether you are using a VPN? I know from experience that using a VPN, whether you are in the UK or not, is not possible.
Recognised Expert
Message 4 of 12
Re: VC003
Sorry Keith, our posts crossed!
Message 5 of 12
Re: VC003
@Skippersam if you are using an Apple mobile phone, you need to make sure the Apple Location Services are enabled.
Message 6 of 12
Re: VC003
Iphone 8+ scotland
It used to be ok but since back from norway i get error vc003
Message 7 of 12
Re: VC003
Location services are on
Iam not using von
Message 8 of 12
Re: VC003
See my last post. Make sure location services are showing a UK location, as it may not have updated.
https://support.apple.com/en-gb/HT207092
Try restarting the phone.
Message 9 of 12
Re: VC003
Vpn
BT TV Expert
Message 10 of 12
Re: VC003
Hi @Skippersam
If you are experiencing VC003, then yes, we are blocking BT Sport streaming due to seeing your device IP address as being outside of the EU 'or' there is an app on your device which has a built-in VPN which you do not know about and is masking the true location of your device.
It is also possible that BT have blocked the IP address you were using at the time for reasons such as Elite Proxying but you can gain a new IP address by restarting your router.
I think, looking at the email address you used to register on the Forum, your issue has self cleared and is now working which is good.
We will look into the reason why it didn't work to start with Smiley Happy
