collo
Message 1 of 5
VC018 error continuosly
Hi
I'm having a problem with my pc and my laptop at work trying to watch the BT sport online
I run windows 8.1 with ie 11 but continually get VC018 time after time, all the sire says is refresh log out log in, nothing changes.
I try on safari, same thing continuosly.
It used to work and play, been about 6 weeks now that I have not been able to play the online player, but my lap top at home plays the player fine, with the same log in details.
I've uninstalled silverlight so many times, that can't be at fault, I've deleted all my cache and cookies also endless times
Can anyone help ?
4 REPLIES 4
Message 2 of 5
Re: VC018 error continuosly
does this link help https://community.bt.com/t5/Watching-BT-Sport-via-the-App-or/Thoroughly-fed-up-VC018/m-p/1265021/hig...
collo
Message 3 of 5
Thanks for the reply, but the solution is for XP or windows 7 I use 8.1 and can't get it to work.
collo
Message 4 of 5
still not working, is anyone out there able to help with this VC018 error ???
Moderator
Moderator
Message 5 of 5
Hi collo
I noticed you've mentioned that it works fine at home but you can't use it at work.  Is your work connection using severs that are located abroad. If your work IP address shows you as outside the UK it may prevent you from watching sport on that particular connection.
Neil
