Message 1 of 4
Vc003 error
Hi
I live in Northern Ireland but when I try to use the by sport app I get error code vc003
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Vc003 error
Hi @Lizalou,
What device are you using the BT Sport App on? If you using and Apple device, location services need to be enabled for the BT Sport App.
PaddyB
Message 3 of 4
Re: Vc003 error
Hi paddy
It is an apple device and the location service is enabled. We have had this issue before it seems to be with BT not recognising my broadband provider.
Here is the explanation I was previously provided;
: Vc003 error code
Hi @Lizalou,
We've not been able to see exactly what's happening regarding the IP address from your ISP. I've raised this with our IP intelligence database provider, and they have seen that IP used recently for VPN/proxy activity - which is why it's being blocked and recognised as not in the EU. It's possible that the IP has been repurposed/reallocated now. We'll be making a change next Monday to whitelist the IP while it's sorted in the background, so you should be able to watch in the app again from then. Thanks for bringing this to my attention and for your patience.
Kind Regards,
Colin
Moderator
Moderator
Message 4 of 4
Re: Vc003 error
Hi @Lizalou  and welcome back.
Thanks for confirming the location service is enabled. I think we'll need to take a closer look into this for you. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
David
