Pardeep30
Newbie
Message 1 of 4
bt sport app not casting
Hi - my BT sport app has stopped casting recently. It worked fine before so I don't understand why? I have reset the app/updated my phone etc but nothing. I get as far as it finding my TV but when I click on the TV name it just doesn't do anything. Can anyone help pls?
3 REPLIES 3
-Richie-
Expert
Message 2 of 4
Re: bt sport app not casting
Hvae you changed your BT Sport package ? If you now get BT Sport free due to your BT mobile then casting is not supported, any other means does support casting.
Moderator
Moderator
Message 3 of 4
Hi @Pardeep30
Welcome and thanks for posting!
Sorry you're having problems casting with the BT Sport app.  Do you get any on screen messages saying casting is not supported with your subscription?  Also, can you check an alternative VOD service like BBC iPlayer to see if you can cast that?
Cheers,
Robbie
Moderator
Moderator
Message 4 of 4
Hi @Pardeep30  Did you get this issue resolved?
cheers
John
