daz28
Newbie
Message 1 of 2
bt sport
picture breaking up on bt sport channels only
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: bt sport
Hi @daz28,
I'm sorry to see that you had problems a few days ago. I wanted to check in with you to make sure everything is ok or else to see if you needed my support.
DanielS
Community ModeratorDannyS
Show your appreciation!
Kudos”Kudos”
