davier
Message 1 of 23
cant get bt sport on bt vision
on help&settings>entitlement information it says status suspended .what does this mean?
22 REPLIES 22
Guru
Message 2 of 23
Re: cant get bt sport on bt vision
Good question. Never seen that before.
Is any of the Vision service working?
davier
Message 3 of 23
full service except for bt sport.ethernet cable from hub to box,terrestial   tv ariel   not infinity
full contentof entitlement information is
  bt admin             28/08/2013
  next connection date    01/01/2038
  last   connection date    28/08/2013(vmc027)
  status                          suspended
Guru
Message 4 of 23
At the bottom of that page is a "Reset Registration" button. Give it a press.
Then go to "CANetwork Infirmation" and press the "Force Resynchronisation" button.
Any change?
davier
Message 5 of 23
still the same
davier
Message 6 of 23
message comes up saying       unable to update subscriptions at the moment try again later error vmc038
Guru
Message 7 of 23
On the first page you were on, what was your entitlement?
davier
Message 8 of 23
entitllement information box         same as previous post concerning "status  suspended "
my bt viewing is inserted but has not been recognised on screen
Guru
Message 9 of 23
Does it have a list like, Essentials Extra, PSD HD etc?
davier
Message 10 of 23
no list of any channels  i do not get a fibre optic connection just asdl hence bt essential only
