cockms
Message 1 of 4
data usage internet channels
Hi folks
I had infinity 1 installed yesterday & have youview box also. Forgive my ignorance but does watching any of the internet channels like bt sports use my data up? I have the 40gb max allowance.
Si
3 REPLIES 3
Guru
Message 2 of 4
Re: data usage internet channels
cockms
Message 3 of 4
Thanks a lot! Also im slightly cheesed off that you cant pause, rewind & record bt sports??!
Guru
Message 4 of 4
Hi, that should be switched on later this year. Allegedly.
