spaceman
Message 1 of 5
free bt sport
Hi,I have just downloaded Windows 10,and I can't access BT sport. I'm told I can't use google and must use I E,but W10 does not seem to support it.
4 REPLIES 4
gomezz
Recognised Expert
Message 2 of 5
Re: free bt sport
As I understand it the new Windows browser, Edge, has an IE mode for those web sites that need it.
Distinguished Guru
Message 3 of 5
Re: free bt sport
If you hunt around, Internet Explorer is still there for compatibility with old web sites.  Silverlight should also work on Firefox.
spaceman
Message 4 of 5
Re: free bt sport
Thanks,gomezz.I did find it 'Edge'.
spaceman
Message 5 of 5
Re: free bt sport
Thanks Ectophile,I found it in 'Edge',and also found I.E after a search.
