piemans
Newbie
Message 1 of 23
mobile data usage for streaming content is disabled message
App works fine on my Galaxy S3 over wifi. But message "mobile data usage for streaming content is disabled" on 3G. Is this a BT issue or my network?
22 REPLIES 22
Message 2 of 23
Re: mobile data usage for streaming content is disabled message
do you have data roaming turned off?
piemans
Newbie
Message 3 of 23
I do
Message 4 of 23
then turn it on but make sure you have a data package with your sim and how much data you can use otherwise you will be charged
piemans
Newbie
Message 5 of 23
Uuum. Data roaming switched on. No change.
I have a full monty package which includes unlimited data. Youtube and BBC iplayer working fine.
Message 6 of 23
tried and getting same as you so looks like wifi only
piemans
Newbie
Message 7 of 23
...but advertised as available over 3G/4G
Message 8 of 23
it does maybe someone else will try and post a solution
Distinguished Guru
Message 9 of 23
Click on the three horizontal bars at top left of App. This opens the menu screen. At bottom right is is a settings icon. Go there and enable streaming.
I expect a star for this 🙂
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
Distinguished Expert
Message 10 of 23
That works Stuart 🙂
To say thanks for a helpful answer, please click the white star
