Tech3
Message 1 of 7
new link for BT sport errors it works
Well just been sent a link from BT by txt for the high level code errors all the 60+ plus the VC error codes.
I am now watching BTsport via my computer, the link i am about to publish ! all you have to do is download it...then let the software install and scan the silverlight, once done ! reboot your computer sign in but don't click watch now, sign out close your browser then go back to BT sport.
sign back in leave it for at least 30 second's then click watch now pick the channel you want and you should be up and away viewing with no problem's, it's work brilliantly for me so i hope it work's for you all
http://tinyurl.com/llk8xx2
if this has helped please click the white star under my name...Happy viewing to everyone that has nothing but headaches trying to view:)
6 REPLIES 6
Distinguished Expert
Message 2 of 7
Re: new link for BT sport errors it works
That link doesn't work
To say thanks for a helpful answer, please click the white star
Tech3
Message 3 of 7
Please follow the instructions to the letter, i messed up twice by not following it completely as it was worded to me.
Distinguished Guru
Distinguished Guru
Message 4 of 7
It's not the instructions that don't work, it's the link:
Distinguished Guru
Message 5 of 7
codex
Message 6 of 7
hi tech3 sorry i did not read you recent post but reading this one .ho boy have you been given the run around there is not a lot of people want to do what you have done bt should get there act together. i glad you are up and running. regards. codex
Tech3
Message 7 of 7
http://bt.custhelp.com/app/answers/detail/a_id/45987/~/bt-sport-app-and-online-player-error-messages
This site doesn't give a solution to silverlight error's, it just gives you code's that are known to BT ! member's want a link to a site with error code's that can be fixed.
Tech3 browse my problem's then finaly the solution i got from BT themselves
